Industrial Communications
Cannot connect to DeviceNet. Getting Error -2147036511
I'm getting the following error when connecting to DeviceNet 15.0 from LabVIEW 2015 SP1 through the PXI-8532 DeviceNet interface connected on a  PXI-1042Q chassis:
Error -2147136511 occurred at Open DeviceNet Interface.vi
Possible reason(s):
An internal fault occurs in the NI-DeviceNet driver. Please contact National Instruments and provide the information from the file %InstallPath%\National Instruments\NI-Industrial Communications for DeviceNet\niDnetErr.log.
The Code is as simple as I can get it: 'Open DeviceNet Interface.vi' and 'Close Object.vi' from the Industrial Communications subVIs.
The niDnetErr.log has the following information:
Severity: Error
Type: System Service
Component: 27
File: 1
Line: 88
Code(hex): 0x00000420
Info(hex): 0xec01c058
(4,101 Views)
Solved the problem by moving the PXI-8532 from slot 8 to slot 2 on the PXI chassis and getting all other cards in the system out..  I'm successfully communicating to a Brooks SLA5850 mass flow controller.
(4,098 Views)
