Industrial Communications
Can't add EtherCAT Master with sbrio 9651 and LabVIEW 2021
Hi all!
I'm trying to control a motor by EtherCAT for my project.
I prepared required hardware (sbrio 9651 and it's carrier board) and software (LabVIEW 2021, real time module, FPGA module, CRio driver 21.0, Industrial communication for EtherCAT 21.5).
And LabVIEW 2021 runs on Parallels window 10 on intel Macbook Pro.
My sbrio 9651 is added on a new black project, and I generated new CLIP enabling second Ethernet port used.
When I compiled a simple vi on FPGA, it worked well.
As a next step, I tried to add EtherCAT master, but EtherCAT master device does not appear in the list.
However, it was possible to add EtherCAT master with LaVIEW 2017, CRio 17.0, and Industrial communication for EtherCAT 17.0.
Due to product license issue, I want to use LabVIEW 2021.
Can someone help me to solve this problem?
(1,572 Views)
Does your ethernet adapter set to EtherCAT mode and present in NI max ?
I know it's an old thread. Did you fix your problem?
(1,272 Views)
