Hobbyist Toolkit
Contributing to the LINX toolkit?
Just a heads up for you. there are available 2 versions of LINX.
3.0.1.192 from Digilent, also called Digilent LINX (this is the older version)
and
1.0.0.9 from NI, also called NI LabVIEW LINX Toolkit (this is the newer one)
if you use community edition, then you have installed the NI LabVIEW LINX Toolkit
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
Message 11 of 17
(1,856 Views)
I see, there is the maker hub 1.x and the NI1.x ;).
 NI LabVIEW LINX Toolkit requires labview 2020 or later. I guess I will have to buy a  newer version...
thanks!
Message 12 of 17
(1,851 Views)
I'll just throw out there as well that going forward it's the Hobbyist Toolkit and is no longer referred to as Linx. If you try searching NIPM for "linx" you'll see a bunch of FPGA stuff first but "hobbyist" comes up with the one result. I'm not sure how back that works for though.
Message 13 of 17
(1,819 Views)
Derrick, is there any plan on community edition allowing us to use RT and FPGA in myRIO?
i know that those are focused on academic and such. but i really would love to use mine outside work and bring home to tinker.
Sistema Fiep
CLAD, CLD
Message 14 of 17
(1,809 Views)
I wouldn't expect so. As far as I know the myRIO isn't officially supported anymore.
Message 15 of 17
(1,801 Views)
Is that true? I was under the impression CompactRIO 2022 or something should add back support for it. If the mRIO is totally unsupported now It think that would be rather bad.
Not for further development I could understand, but maintaining its operation together with some of the other cRIO targets that are nowadays considered mature such as the 903x and 906x would be definitely expected for a few more years.
That FPGA and RT won't be part of the Community Edition is an entirely different story and I can certainly see why that is not currently considered. Of course I can also see, why someone would want to ask it anyways. 😀
As we say in Dutch, you can get a YES if you ask, but will always have a NO if you don't.
Rolf Kalbermatter  My Blog
Message 16 of 17
(1,796 Views)
i had the same impression since myRIO toolkit 2021 is available since end of july.
and if the NO i already have, then i ask hoping for the YES
Sistema Fiep
CLAD, CLD
Message 17 of 17
(1,792 Views)
