 CBS
			CBS
			02-08-2006 10:25 AM
 JLS
			JLS
			02-09-2006 05:11 PM
If you launch the example finder (Help -> Find Examples... in LabVIEW) and use the word spectrum in the search field, you'll find many examples. Perhaps you are interestd in Power Spectrum Measurement.vi in particular.
Best Regards,
JLS
02-09-2006 06:02 PM
Thank you for your input!
I am trying to use Frequency Spectrum Analyzer for NI-SCOPE (NI 5911) that I downloaded from NI Developer Zone.
What I need to know is how to store the data from auto power spectrum vi. I tried to use write Labview measurement file vi connecting power spectrum output at auto power spectrum vi. Also between the auto power spectrum vi and write Labview measurement file vi, there is a convert to dynamic data vi which is automatically inserted after the wiring. After running the get spectrum vi, it give me a error with status 7 and no data files created.
Please help!
CBS
 JLS
			JLS
			02-09-2006 06:15 PM
02-09-2006 11:15 PM
Thank you, JLS!
I was successful to write a file into a binary, but still strugglling with read! I need to do more practice as you can see I am a complete novice with Labview.
CBS
 JLS
			JLS
			02-10-2006 01:34 PM
 JLS
			JLS
			02-10-2006 01:36 PM
02-20-2006 09:05 PM
I tried to use Frequency Spectrum Analyzer for NI-SCOPE (NI 5911) vi that I downloaded. However, the vi gives output with only a single scane. I need to have output as you will see in attached vi. How should I make this vi work with NI 5911? Will you help me to make the attached vi to be used with NI 5911? I am struggling with this quite a time and still cannot find a way to make this work! If you can find the solution, your help would be greatly appreciated!
CBS
 kalyanramuv
			kalyanramuv
			02-23-2006 11:12 AM
