High-Speed Digitizers
Reading data with NI-5772
I am trying to read data with the NI-5772.  I have tried the example code(NI 5772 - Getting Started (Host).vi) , and it will read noise (with nothing plugged in to either channel).   However when I attempt to route a signal in (such as one generated with a NI-DAQ board on the same system and routed to AI0/AI1), the signal doesn't change much from the noise.   I updated the drivers and am running LabView 2012 (both 32-bit and 64-bit, I get the same result)
Has anyone else experience this problem?   Thanks.
(6,502 Views)
Ok,  apparently it just didn't like our input signal  ( a 1 khz sine wave generated from NI-MAX).  We tried a source with a higher output rate (several MHz) it seems to work OK.  Is there some sort of high pass filter on the input?
(6,497 Views)
Accepted by topic author PatrickR
Yes, the device is AC coupled and has a high pass filter.  There is a frequency response graph on p.20 of the User's Manual:
https://www.ni.com/docs/en-US/bundle/ni-5772-seri/resource/373625b.pdf
It appears that the cuttoff frequency is about 100kHz.
Systems Engineer
SISU
(6,471 Views)
