High-Speed Digitizers
How do I determine the amount of on-board memory on PXI-5114?
How do I determine the amount of on-board memory I have on my PXI-5114?
Thansk in advance.
(7,292 Views)
Hi VI Joe,
This really depends on which version of the card you have purchased.  If you notice from the product page there are three different cards that vary in price.  This variation is in relation to memory per channel.  From the spec sheet the onboard memory options are:
Kyle S
Regional Account Manager
NI
(7,284 Views)
I already have the card in a working system.  Is there a way I can tell which memory option I have (e.g. MAX, etc.)?
(7,278 Views)
Accepted by VI_Joe
I apologize I did not realize you already had the card.  There is a property node for NI Scope to determine the total amount of available memory that we can then divide down to get the available memory per channel.  Please see the vi and help below:
Give this a shot, just drop it into an existing VI that you are using and it should return your cards memory.  If you do not have LabVIEW I can most likely retrieve the version you purchased by querying your Serial Number.
Kyle S
NI
(7,274 Views)
