General
Broken RoboRio 2.0
Had problem at competition after a match. when trying to do a system check we were unable to get a roboRIO connection.
We reached out to support and they said to repost it again on this forum in order to get a replacement through warranty
Message 1 of 9
(391 Views)
Hi
This is Juan Garcia from NI Technical Support.
Can you please share more details about what broke so we can document the replacement?
Message 2 of 9
(346 Views)
We received an “Unrecoverable Error” status light after a normal match, we don’t know what caused it.
We noticed it post match when trying to connect to do a system check.
One of our other team mentors said they contacted support previously, and was told to post on the forum here
Message 3 of 9
(338 Views)
Please try the following:
  1. Turning the roboRIO upside down and shaking it vigorously.
  2. Vacuuming out the ports on the roboRIO.
  3. Use canned air or compressed air to clear the hardware pinouts.
  4. Check with a flashlight for material making contact in the port pinouts.
You can also try using a different SD card
Message 4 of 9
(334 Views)
Speaking with the mentor, all proposed solutions were attempted at & post competition with a CSA. We could not get the error code to go away
Message 5 of 9
(325 Views)
Can you please share a contact email so we can provide more steps to replace the roboRIO?
Regards.
Message 6 of 9
(306 Views)
our email is {email removed by moderator and shared internally}
thank you!
Message 7 of 9
(301 Views)
Hi team, following up. Do you have an update on our replacement roborio?
We sent an email with all the requested information, but haven't heard back in almost a week.
Thank you!
Message 8 of 9
(257 Views)
We received the RoboRio today, thank you for your help team!!!
Message 9 of 9
(244 Views)
