G#
Performance for Creating Objects
So of late I have been trying to convert the Gold Parser Engine into labview. However after looking at the code and seeing how dependent on pointers it is I decided to use the G# Framework. And after a while i got it to work, yes there is a few bugs i still need to work out. But one concern is the performance of G# when creating many objects. LRActions and such which there are thousands of in a fairly simple grammer. And strings Since labview doesnt support UTF16.
However I see to be running into performance issues when creating large number of objects quickly. The Visual basic version loaded the file in about 15ms but the G# version is running around 1000ms not that this is at all the fault of G# and not somewhat my fault. but I did notices that G#Object.lvclass:GetClassName spend a good amount of time on calls. Perhaps I need to do some restructureing or some type of refactoring.
I did look at the performance Examples and try to make as few copies for large objects as possible.
(8,726 Views)
You have an average of 0ms, but if you could share the code we can analyze and test. Fixing bottlenecks is always important.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(7,404 Views)
Why Not ?
https://decibel.ni.com/content/docs/DOC-41064
Please let me know if you can find the performance issue. Its under Parser LoadTables i have it setup to run by itself currently. (1/15/2015)
You'll need a EGT to try it. Here is one I've been using.
(7,404 Views)
I had a look at this problem in general and made some improvments to the G#Object.lvclass:
* Improved performance in GetClassName.vi by caching last result and use the same answer if needed.
* Performance improvement in NewObject. No need to check if external process is running when "no registration" is checked.
We will include these in the next release. Please notice that I have not tried this on your code.
You may also want to try the "No registration" boolean input of the G#Object_New.vi inside your constructor, this is default set to false, but if you set this to true, performance will be increase about a factor 2, but you will not see the object with the G#Debugger or can't use the G# Garbage Collector.
With the new improvements (with No registration = true), my test class of 10000 objects was created in 800 ms, compare to 2875 ms with the old implementation (with No registration = false). Please let us know the results.
If you just have one class that you would like to create many objects with high performance from just to represent some datastructure, I would perhaps recommend to use not a G# class, but perhaps just a standard LabVIEW class with a DVR inside or a queue directly. Since G# is not native LabVIEW syntax, there will always be performance compromises compared to tracking the objects, but I see no problem combining G# classes with other "class" implementation where needed. I've done this myself many times.
Please replace your:
C:\Program Files (x86)\National Instruments\LabVIEW <version>\vi.lib\addons\_AddQ\G#Object
with the one attached. Please notice this code is LV2010.
Mattias
(7,404 Views)
