01-15-2015 11:41 AM
So of late I have been trying to convert the Gold Parser Engine into labview. However after looking at the code and seeing how dependent on pointers it is I decided to use the G# Framework. And after a while i got it to work, yes there is a few bugs i still need to work out. But one concern is the performance of G# when creating many objects. LRActions and such which there are thousands of in a fairly simple grammer. And strings Since labview doesnt support UTF16.
However I see to be running into performance issues when creating large number of objects quickly. The Visual basic version loaded the file in about 15ms but the G# version is running around 1000ms not that this is at all the fault of G# and not somewhat my fault. but I did notices that G#Object.lvclass:GetClassName spend a good amount of time on calls. Perhaps I need to do some restructureing or some type of refactoring.
I did look at the performance Examples and try to make as few copies for large objects as possible.
01-15-2015 03:46 PM
You have an average of 0ms, but if you could share the code we can analyze and test. Fixing bottlenecks is always important.
/Y
01-15-2015 04:43 PM
Why Not ?
https://decibel.ni.com/content/docs/DOC-41064
Please let me know if you can find the performance issue. Its under Parser LoadTables i have it setup to run by itself currently. (1/15/2015)
You'll need a EGT to try it. Here is one I've been using.
01-16-2015 02:23 AM
I had a look at this problem in general and made some improvments to the G#Object.lvclass:
* Improved performance in GetClassName.vi by caching last result and use the same answer if needed.
* Performance improvement in NewObject. No need to check if external process is running when "no registration" is checked.
We will include these in the next release. Please notice that I have not tried this on your code.
You may also want to try the "No registration" boolean input of the G#Object_New.vi inside your constructor, this is default set to false, but if you set this to true, performance will be increase about a factor 2, but you will not see the object with the G#Debugger or can't use the G# Garbage Collector.
With the new improvements (with No registration = true), my test class of 10000 objects was created in 800 ms, compare to 2875 ms with the old implementation (with No registration = false). Please let us know the results.
If you just have one class that you would like to create many objects with high performance from just to represent some datastructure, I would perhaps recommend to use not a G# class, but perhaps just a standard LabVIEW class with a DVR inside or a queue directly. Since G# is not native LabVIEW syntax, there will always be performance compromises compared to tracking the objects, but I see no problem combining G# classes with other "class" implementation where needed. I've done this myself many times.
Please replace your:
C:\Program Files (x86)\National Instruments\LabVIEW <version>\vi.lib\addons\_AddQ\G#Object
with the one attached. Please notice this code is LV2010.
Mattias
