04-15-2022 08:26 AM
Hi, I'm new with G Web development software.
I'm not able to run a VI. As you can see in the picture in attachment if I try to simply run an example gviweb I obtain Run panel failed to load. Error code: -118: ERR_CONNECTION_TIMED_OUT.
What am I doing wrong?
04-15-2022 09:58 AM
Hi TAZ22,
I think you may have missed including the attachment showing the error.
05-16-2022 04:39 AM - edited 05-16-2022 04:41 AM
I had the same issue that I got the “Run panel failed to load”-Error when I tried to run any gviweb files.
For me the issue was the configuration in NI web server, where the host named referred to an IP-adresse that me PC no longer was on, after changing it to localhost the problem was resolved. (Using the PC name also worked)
