‎05-19-2022 01:46 PM
I'm trying to Publish a Web Service but cannot locate the Web Application Server
Anyone have any ideas?
Keith
‎05-19-2022 05:42 PM
Hi Keith,
First, it is recommended to use the NI Web Server (LV 2020 and later) since the Application Web Server is getting deprecated. Check if the NI System Web Server and the NI Application Web Server are running. You can also check this KB for further troubleshooting steps: Configure Web Application Server Disabled in LabVIEW Options.
‎06-02-2022 06:16 AM
Application web server is getting deprecated? Do you have more info on this? How does NI intend to allow G Web pages to be hosted on a Real-Time device going forward?
‎06-02-2022 10:36 AM
Hi jvon20,
The NI Web Server is recommended if used on Windows if you are running it on a real-time target, then continue to use the Application Web Server. The AWS will continue to be released with LabVIEW.
To troubleshoot this issue you can follow the steps in this KB: Error 404 Page Cannot Be Found When Using Remote Front Panels and Web Services.
