G Web Development Software
Array to Spreadsheet String and Spreadsheet String to Array
I have a need to use the same functionality as the LabView Array to Spreadsheet String and Spreadsheet String to Array VIs in order to process comma-separate strings in tags.  But, I don't see these in the available GWeb VIs.  Are these available somewhere else?  If not, I'll have to reproduce them (any suggestions on the best way would be appreciated).  Thank you.
(1,855 Views)
The easiest route is perhaps a for loop over all of the string elements and on every iteration past 0 you also prepend the separator.
If you want to be a bit more optimal you first iterate over the elements to sum up the total resulting string length (don't forget to include the (number of elements minus 1) * size of separator), allocate a string of that length, and do replace subset across the new string for each element.
~ Helping pave the path to long-term living and thriving in space. ~
(1,834 Views)
Thank you for your quick response.  And the reverse to take a tag value that is a comma separate string; parse each substring with string subset, or search/split string and create a 1D array of substrings?
(1,826 Views)
