11-30-2021 02:24 PM
I have an XY Graph that I've set up for time on the X-axis. I want to show 24-hour time on the axis.
The way I've done that is set the X-axis formatting to "Absolute Time", and then selected the time format to be "hh:mm". Beneath that, there's a pair of radio buttons for AM/PM or 24-hour time. When I select 24-hour time, it looks like it uses 12-hour time without the AM/PM indicator. I would expect, for example, that "05:00 PM" becomes "17:00". But from what I can tell, "05:00 PM" becomes "05:00".
Am I doing something wrong? Is there an alternate way to get 24-hour time on the axis?
Screenshots below:
11-30-2021 02:37 PM
I meant to test this in both the IDE and the browser (Chrome, in my case) before posting, but forgot to test the browser.
I get correct results in the browser. Here's another screenshot, with the G Web IDE on the left, and Chrome on the right.
So I suspect this is just a bug in the IDE.
12-01-2021 03:42 PM
Brian,
How did you get the correct timestamps to show up on the time axis in absolute mode?
I have waveform data that I am pushing from an RT target but the JSON in the message API will not accept a waveform type.
12-02-2021 09:45 AM
Hi, Steven. I am using the timestamp data type as my X data type. I have nonlinear spacing of data, so I started with an array of cluster of timestamp and double. I needed to add multiple plots, so I switched to an array of cluster of array of timestamp and array of double. (I think I have that right.)
12-04-2021 02:30 PM
Thanks Brian,
Appreciate the help.
