Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Parallel processing: for loop unfolding
Risolto!
Vai alla soluzione
Hallo,
I've a "for" loop runnin on this system:LabVIEW2009, windows7, intel i7.
I wonder if and how I can tell to LabVIEW that it would be allowd to execute the different iterations of the loop at the same time (in parallel) on my 8 cores processor.
Now it execute the next iteration when it finish the previous one even if is there no dependecies within the iterations.
I'd like give a "property" to the loop that mean it can be "unfolded" for parallel execution.
Pier
Messaggio 1 di 2
6.112Visualizzazioni
Soluzione
Accettato da autore argomento Pier Paolo
Hello Pier Paolo,
There is a parallel for loop you can use in LabVIEW 2009. You can right click on the for loop and select "Configure Iteration Parallelism..." and set it to execute in parallel.
- Mike Benza
-- Mike
Messaggio 2 di 2
6.109Visualizzazioni
