FlexLogger
logging problem- log only part of the channels
HI,
I have a strainge problem: after set up for the test was ready i made a sample run to check the logging system. everything worked properly- all sensors responded and all data from all of the cannels was logged. than i run the test and when i was looking at the logged data I saw only 1/3 of the channels has been reccorded. didn't chainge any setting alog the way.
Any idea we it happend?
(1,674 Views)
Dear  Naveh77 ,
What hardware are you using? Maybe the problem is in physical level, check that wires are properly connected and everything is in their place.
If that doesn't work restart the program and try again.
(1,630 Views)
