FlexLogger
if, then, else programming in FlexLogger
Hello everyone,
I would like to realize an if, then, else programming in FlexLogger and I don't know how to implement it.
I want to display a pressure. If p<0.1Pa, then p=0.1Pa should be displayed, else(p>0.1Pa) p=p should be displayed.
Is this possible with an arithmetic formula? Or is there another way to implement this?
I would be very grateful for your help.
Best regards
zarlex
(3,148 Views)
Accepted by zarlex
Hi zarlex,
Yes, the arithmetic formula channel supports the ternary operator which allows you to do it/else logic.  In your case, assuming the channel name is 'p', the formula would look like:
'p' < 0.1 ? 0.1 : 'p'
Or you could invert the logic and write it this way
'p' >= 0.1 ? 'p' : 0.1
Hope that helps!
(3,115 Views)
Hi Devin,
Thank you very much. It works perfectly.
best regards
zarlex
(3,093 Views)
