FlexLogger
Graph Limits (Upper/Lower) accessible programmatically or by variable?
I'm working on a project where i have Long History Graph and I'm needing to programmatically scale the Window Loose fit which i was able to find and then update the Upper Limit and Lower Limit hopefully from a variable or via LabVIEW Plugin. I am unable to find any information on this in any of the manuals.
I was clicking areas on the Graph and was able to find the Type LongHistoryLengthGraphAxisModel and Limits at the bottom of that Item Field.
Are these values accessible in any way from a plugin or is there a way to point this value to a variable. I tried typing it in the field but it appears to only accept numeric values?
Are my Graphs limits, Limited?
Message 1 of 1
(1,004 Views)
