FlexLogger
FlexLogger Plugin SDK Remove Channels Not Working
I'm experiencing odd behavior when I try to dynamically control the number of channels in my plugin. I copied the example program out of the 1.3 manual (in LabVIEW 2020). When I load the plugin into FlexLogger, everything seems fine, and I can add channels just fine.
The issues come when I try to remove channels. The channels will be removed, but then blip right back into existence. I put a pause in the Configure Session.vi as an ad-hoc debug, and the behavior paused accordingly, suggesting the issue is in Process or Cleanup.
Has anyone else had this issue? I can put a code snippet if needed, but it's exactly the same diagram as listed in the 1.3 manual for the SDK.
Thanks.
(3,844 Views)
Just got back from vacation so I'll investigate this today. What release of FlexLogger did you install? If you don't mind attaching your plugin to ensure I'm testing the same code you are using, that would also be helpful.
Brad
(3,800 Views)
Thank you for taking on the request. I've attached a zip of the project to this reply. It's the "testing" phase files.
Let me know if you spot anything wrong.
Regards.
(3,777 Views)
Thanks for the attachment. I've reproduced the problem with the latest FlexLogger and verified an older version (FlexLogger 2020 R4) works well, so I am investigating further now.
Thanks for bringing this to our attention.
Brad
(3,771 Views)
Accepted by topic author ValveAutomator
I was able to fix this issue so the next release of FlexLogger will have this fixed. The next version should be available around April. Unfortunately I haven't found a way to work around this problem with the current software. I also added some tests to ensure this capability doesn't break in the future. Let me know if waiting until the April release will be acceptable.
Brad
(3,728 Views)
Thank you for remedying the situation. Glad I could bring something to NI's attention 👍
(3,716 Views)
