FieldPoint Family
write TDM file in to compact flash
hi,
I've a cfp2120  with a compact flash , i try to write a tdm file into this compact flash ( the cfp work in stand alone no pc are connected) but it doesn't work.
i've try to define the adresse into de express vi for the tdm file ( example 10.132.1.2/d/test.tdm) and also d:/test.tdm but doesn't work.
It's somebody can help me?
i join my file
thanks
(3,428 Views)
Hi Mikl,
   I've tried to open your VI, with my LabVIEW 7.1,  but only the main window of LV opens (the VI actually is not opened), I don't know why....
   Anyway, I normally use the compact flash in my cFP-2020 (similar to 2120), and it works, maybe the problem is with express vi or tdm file management...
   About express VIs and embedded cFP applications, I was suggested to avoid them, because in general, they  can be less efficient than normal functions. In cFP-2020 (75 MHz) that matters!
   Bye!
graziano
(3,425 Views)
