FieldPoint Family
unable to switch executable tp RT network
Hi
I have problem when i switch executable to RT newtwork (fieldpoint).I mean switch to run at fieldpoint. when i switch to run at field point, an error was occured.It said that " Unable to loacte the LabVIEW run time engine,LVBrokerAux70 requires a version 7.0rc0( or compatible) LabVIEW Run-time engine.Please contact the vendor of LVBrokerAux70 to correct this problem." I have attached the picture of error massage at below. Any one can tell me how can i do to solve this problem? THANKS
(3,985 Views)
Hello Barry. Thank you for contacting National Instruments. When running an executable on you Fieldpoint controller you need the LabVIEW Run-Time Engine and the Measurement and Automation Explorer. Based on the error that you are getting, your program was written with LabVIEW 7.0, so you need that version of the Run-Time Engine. You can download the Run-Time Engine for free on ni.com here. Please let me know if you have any questions. Have a great day!
Marni S.
(3,963 Views)
hi,Marni
Thank for your adivce,that is helpful.But another problem is discovered. After i have updated the OS and installed the Real Time 7.1, i cann't cogfigurate the fp2000.When i click the 'FIND DEVICE',it said that " the connection to a remote device timed out."
Laview software configuration as following:
LabVIEW: 7.1
LabVIEW Real-Time: 7.1
MAX: 3.1.1
Can anyone tell me how to handle this problem? THANKS
(3,951 Views)
I have previously seen instances when upgrading the OS on the FP controllers, after the reboot, the Gateway IP address would be set incorrectly. Check the network settings on the controller, fix any incorrect ones, and reapply the network settings. After that you should be okay.
Aaron
LabVIEW Champion, CLA, CPI
(3,946 Views)
