04-07-2008 02:44 AM
I AM FACING THIS ERROR CODE WHILE BUILDING MY APPLICATION IN AN EXECUTABLE.
The VI is broken. Open the VI in LabVIEW and fix the errors.
D:\JUICE EXTRACTION only ethernet\VI\Scada.vi
<Call Chain>Error 1003 occurred at AB_Application.lvclass:Open_Top_Level_VIs.vi -> AB_Build.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Page_Preview.vi
Possible reason(s):
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the VI in LabVIEW using File>>Open and verify that it is runnable.
my email id is sarbalhi.samriddh@gmail.com
04-07-2008 08:43 AM
First question,
Have you tried opening that sub-VI to see if it is broken?
04-07-2008 09:13 AM
hi,
yes i had also tried to open the vi in labview and it is excutable.
i had also tried the command "ctrl + shift + run" button on the front panel in hope that it will show the internal broken vi or the error. the vi is executable and it works.
but in vain.
please suggest any better solution.
waiting for the response.
thanks.
samriddh sarbalhi
05-08-2008 12:17 PM - edited 05-08-2008 12:18 PM
05-08-2008 12:37 PM
05-23-2008 03:52 AM
hi,
i have designed an application having four security levels like administrators, engineers, operators & guests.
now i want that whenever the guest logins in my application, windows components on the desktop will not be accessible to him means he can only view my application but he will not be able to view start menu on the task bar of the windows page or any icon on the desktop.
please tell me how to accomplish it progarmatically using labview.
the appropriate response will be highly appriciable.
thanks
samriddh sarbalhi
05-23-2008 03:53 AM
hi,
thanks
samriddh sarbalhi
05-23-2008 12:30 PM
05-24-2008 01:57 AM
hi ravenas,
thanks for the reply.
anyways, is it possible that whenever guest logins into the system, the windows page bounds configuration like front panel bounds in labview be fetched so that the same will be configured to the vi's front panel programatically.
by doing this the windows components will automatically get hide.
or is there any better solution.
reply
thanks
samriddh sarbalhi
