08-21-2007 02:23 PM
08-21-2007 02:55 PM
08-21-2007 03:06 PM
Labview 7.1
08-21-2007 03:26 PM
There are several ways to communicate with cFP. I prefer to use TCP for communicating between PC host and cFP target via network. There are TCP examples that ship with LV and I'm sure you can find numerous references on the ni webpage.
You can also use DataSocket and Logos.
08-22-2007 09:26 AM
i'm runing a Vi in the cFP in realtime and i need to do a routine in the cFP Vi if the varaiable that is runing at same time in windows change. i'm conecting with the cFP by network
Do you believe that this can be with TCP ?
08-22-2007 10:41 AM
Yes, it can be done with TCP/IP.
See this example of communication on the NI web page. http://zone.ni.com/devzone/cda/epd/p/id/2088
08-22-2007 03:10 PM
