FieldPoint Family
fpga
Hi everybody
I am new in using FIFO DMA and I am having some problems in getting started.
I am using a compactRIO 9073 with a NI9234 Analog Input module.
I have used the FPGA Wizard tool to configure the data acquisition.
Attached you can find the FPGA VI, the Host VI and the FPGA configuration file.
The problem is that I can't get to acquire any data, because the VI stops since the FIFO is always in Underflow Condition.
Do you know how to fix the problem?
Daniele
(6,177 Views)
This forum is for Fieldpoint and compact Fieldpoint questions.
You should post your FPGA question in the LabVIEW board.
(6,165 Views)
