FieldPoint Family
fieldpointinapplicationbuilder
I have an application Field Point based and i want to distribute with the application builder.
I insert the fplvmgr.dll and the iak file location but the application haven't any effects with the Field point bank.
The application run correctly buat not network with FP resources.
Bytelabs.it
(3,381 Views)
It sounds like you are building an executable to run on another Windows PC. If this is not the case (i.e. you are building a LabVIEW Real-Time executable to run on the FP-20XX module) please respond.
You have to install FieldPoint Explorer and the LabVIEW runtime engine before the exe will run. The LV RTE can be included as part of the installer, but FP Explorer must be manually installed.
My guess is that the "iak file path" input for FP OPen.vi is not pointing to the correct location of the IAK file. If this does not remedy the problem, you should verify that FieldPoint Explorer can
communicate with the devices.
Michael Shasteen
Applications Engineering
www.ni.com/ask
1-866-ASK-MY-NI
(3,381 Views)
