FieldPoint Family
cFp-1808 IP address
I am trying to setup a cFP-1808 and in Max (5.0.0f1) am getting to the screen that needs me to put in the device IP. What is the device IP or where would I find that? I will be using LabView2011 on a XP computer.
Gerald
(6,995 Views)
Here is the screen that is asking for the device IP
(6,991 Views)
How do you get to that screen? Are you trying to "create" a device in MAX?
If there is no network settings issue MAX should see yout cFP, maybe this can help you.
Epictetus
Antoine Chalons
(6,980 Views)
The Windows firewall was blocking the 0.0.0.0 IP address for the initial setup.
Turned off the firewall and the Field point cFP-1808 popped right up turned the firewall back on it is seems to be there.
Now it has been a long time since I worked with field point but the Field Point tool pallet does not show up and the Field point does not show up in the start: Program: National Instruments menu. I will ask that question in the LabView part of the forum.
Gerald
(6,972 Views)
Cool!
Did you change the font size to small on purpose? It's quite hard to read even for a young lad like me Smiley Surprised
Epictetus
Antoine Chalons
(6,969 Views)
No it was a copy and paste. I tried to make it larger and it kept making it small again. Sorry about that
(6,967 Views)
