FieldPoint Family
VxWorks Floating-point support 2.0 missing (LV2011SP1 RIO4.1)
I have a strange problem with a CRIO System (9022) using LV2011SP1 RIO4.1 and MAX5.1.
Since I had older LV Versions on the computer I did some cleaning up in the LV components
and ended up deleting everything which belonged or depended on older LV versions.
Then I re-installed LV2011SP1 plus RT module SP1 plus (hopefully) all drivers needed.
Then I started MAX to update the software on the CRIO target to the versions installed on the host.
However, I cannot do that, I always get the following error:
VxWorks Floating-point support 2.0 missing (not installed on host)
I have no idea which component is missing where this is included.
Could someone please point me to the right package or driver?
TX
(7,156 Views)
Hi Olaf,
to get the Floating-point 2.0 support working you normally need the NI-RIO driver. Since you already have 4.1 installed try to repair it.
Or just redownload the current driver from here:
NI Drivers
Best Regards,
Lam
(7,146 Views)
Accepted by Olaf_Stetzer
Hi, I had the RIO drivers installed, but to avoid a bloat of too many unneeded drivers I had deselected some "support" options where I thought it is save to do so (e.g. support for various porgramming languages including C) since we work only with LV and no additional development environments. I think that this was the problem, the missing part seemed to have been in some of these ANSI C support packages. Now it works. Cheers, Olaf
(7,141 Views)
I am having a similar issue as well. I am trying to install only LabVIEW Real-TIme 11.0.1 on a cRIO 9023 that has no software previously installed. It returns a message saying "LabVIEW Real Time 11.0.1 requires VxWorks Floating Point Support 2.0". I did some research and found LV2011SP1 Real Time Module should install VxWorks 6.3 but I cannot find this or anything related to VxWorks in the list of features to install in MAX.
cookieGT
University of Georgia Alumni
(7,092 Views)
