FieldPoint Family
Use cFP RS-485 port in 2-wire mode
Does that mean that you do not need to join Rx+ and Tx+ etc., and will the switch time be more reasonable then (that's the real problem with the way it used to work; that it is too slow to switch between transmit/receive)?
If not, how is it different than just setting the wire mode on the VISA node?
Message 11 of 14
(1,757 Views)
You are correct, it is the same as setting it through a property node. Modifying the DBS file will change the default behavior when the port is opened.
You will still need to join the wires externally, but you can use 2-wire auto mode, unlike the older Fieldpoints. I am not aware of the switching speed problem you mention, can you elaborate?
Message 12 of 14
(1,748 Views)
JasonS',
My solution talks about the switching speed.
Message 13 of 14
(1,743 Views)
I looked back at how the cFP-2120 did the switching, and for both the cFP-2120 and the cFP-2220 the UARTs themselves are responsible for determining when to turn off the transmitter. The cFP-2220 uses a UART very similar to that used in our PCI/PXI-8431 hardware, so I would expect similar switching performance.
Unfortunately the UART manufacturers do not document this delay in their datasheets, so I cannot provide a direct comparison between the two.
-Jason S.
Message 14 of 14
(1,736 Views)
