FieldPoint Family
Trouble reading data from AI-118 and serial port data from a cFP-2120
I'm using a cFP-2120 controller on a 4-unit backplane housing 3 AI-118 modules and a TC-120 module.  Additionally, I'm trying to read data into the serial port (COM 1) of this controller (weather station data).  If I run the weather station by itself, it seems to work just fine.  When I try to run it with the rest of the software, it acts up, giving lots of communication errors and delays.  I have the same code I'm running as a standalone VI running in parallel with the code reading the AI-118 and TC-120 modules.  I've done this in the past on a different system and it seemed to work just fine, but this time around I'm not having the same luck.  The only difference between then and now is that I ran each as 2 separate VI's running in parallel before whereas now I've got the code in two parallel timed loops in one VI.
I'd sure appreciate a bit of help on this one.
(7,304 Views)
You said that you were using two timed loops.  Which loop has the higher priority?  If you swap the priority of the two loops, does the problem change?
(7,292 Views)
Sorry. but I didn't do a thing with priority, as it's not an issue for me.  This is a SLOW data acquisition system, with the temperature part (Loop 1)only capable of being read once per second, adn the Data Loop (2) being read onve every 1/2 second.
(7,279 Views)
What kind of communication errors are you seeing?
(7,275 Views)
What are the error #s you receive?
-Bob
Message Edited by B O B on 08-08-2007 10:00 AM
(7,272 Views)
I'm sorry......
I did further investigating do to some other "characteristics" of the problem and found a second incident of one of the loops (a separate VI) sitting underneath one of my loops.  I deleted it and everything runs fine now.  Please forgive me my sudden loss of intelligence.
(7,264 Views)
