FieldPoint Family
Rockwell Overload Relay
I'd like to know if i can interface to a Rockwell solid state relay (such as the E3/E3 plus, http://www.ab.com/en/epub/catalogs/12768/229240/229254/229467/353799/tab3.html), which uses devicenet, using only the Ethernet/IP driver for Allen-Bradley PLCs available for Labview. If not, what else do I need? and is there any requirement for the controller/harware in general, other than an ethernet connector?
Thanks in advance.
(6,068 Views)
Hi Mauricio,
Ethernet/IP Driver is in beta version, and you can have support about it in an specific forum. Access the link below to ask about this driver.
http://forums.ni.com/ni/board/message?board.id=nilabs&thread.id=167
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(6,038 Views)
