FieldPoint Family
Rigol DG1062
I am using .  I can’t get a Labview driver for this specific function generator. I try the DG4000. I gives me a signal error and can’t figure it out.  Can you please suggest me how to get the Labview for Rigol DG1062 Arbitrary function generator.
(6,824 Views)
How are you currently coding your function generator in LabVIEW?
And what is the signal error you are receiving?
(6,807 Views)
Hi
Thanks for your answer. I am new to Labview. I have a Rigol DG1062 function generator. I want to triger halfwave sine signal using chanel 1. I want to do this using my PC through the help of Labview. When i search at your catalog you dont have Labview files for Rigol DG1062. But I can see for DG4000. I try that but didnt work. So it is possible to get for Rigol DG1062 ?
Best Regards,
(6,804 Views)
You are correct, there isn't a LabVIEW API driver for that device currently. You can still communicate with the device using standard protocols (VISA perhaps), or you can work on developing an API driver for the device (There is a link on the drivers page for doing this here:
http://www.ni.com/downloads/instrument-drivers/
http://www.ni.com/white-paper/3271/en/
Also, this post should probably be in the Multifunction DAQ Forum, not FieldPoint.
DAQ Forum:
http://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
(6,789 Views)
