FieldPoint Family
Problem with Shared Variables on Compact Fieldpoint
I am having trouble with shared variables deployed to a cFP-2120.The shared variable is working correctly on the host, and I can read shared variables back from the Controller. However, the host is unable to write network shared variables to the controller. I also have other problems with Labview 8, one is that Labview shuts down with a Windows error when it cannot connect to the RT target. If I start up Labview again, the host connects normally without any re-boot. Also when I shut down my pc I also get a Windows error indicating a problem with tagsrvr.exe, which is probably related to my shared variable problem. I have tried 2 different p.c.s and have also tried running the fieldpoint with no Variable Engine manager to no avail. Anybody seen any of these probs?! Help would be very much appreciated.
(3,706 Views)
I believe this has been an ongoing problem which is now resolved but here are some links that where compiled to help
How Do I Distribute A Real-Time Application With Shared Variables To Multiple Users?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P99DSAS&l=en-US
What Happens When my Shared Variable Engine Goes Down Unexpectedly?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019UDCSA2&l=en-US
Troubleshooting Network-Published Shared Variables
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6vdSAC&l=en-US
Errors When Sharing Data Between the RT Module and DSC Module Tags
http://digital.ni.com/public.nsf/websearch/25A737870452946E86256DCC00578F32?OpenDocument
Errors When Using DataSocket and LabVIEW RT
http://digital.ni.com/public.nsf/websearch/D0D96E2A1AB2870986256B1A0052BE41?OpenDocument
Using the LabVIEW Shared Variable
https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html
Regards
Tim
AE NI UK and Irland
(3,679 Views)
