FieldPoint Family
Loading a *.ctl automatically
Hello
I am using Labview with the Simulation Interface Toolkit. The toolkit creates a control (control.ctl for instance) which I need for futher software stuffs. On this control, there is the mapping of he simulink model which I've just linked with my Labview interface. I want to know if there is a way to load automatically teh control without changing the code at every new version of the dll implemented from simulink.
To set up the technical background, we want to implement a simulink model on an embedded test becnh using the toolkit, a cfp and Labview.
Thanks in advance for the future comment and answers.
(3,395 Views)
I m afraid that each time you want to use your control and interface it with a simulink model, you have to create the link.
Isabelle Jean
Isabelle
Ingénieur d'applications
National Instruments France
(3,395 Views)
In fact, I used another way to solve the problem. The toolkit creates a file called themodel.prm, a text file, where the information about mapping is written.
It will copied on the PC, and called to get the parameters of the simulink model.
Then I use another vi to get data from the text file
Thanks for your comments
(3,395 Views)
