FieldPoint Family
How do I change the duty cycle of cFP-PWM-520 module?
Hi
     How can I change the duty cycle when a signal is generated by the compact FieldPoint module cFP-PWM-520?, I can control the period, but the ON time of the signal is not user selectable in the MAX channel attribute, only period(ms) is shown.
Thanks for your help.
 Peter
(6,961 Views)
Peter,
Duty cycle can't be controlled using channel config in MAX.  Can only be controlled by writing a value to the I/O.  See page 7 of this http://www.ni.com/pdf/manuals/323357b.pdf
(6,953 Views)
Thanks Wayne, what would be the sintax to be used when writing to the Channel a change on duty cycle?
(6,947 Views)
I don't have a 520 in to test but since the input range is defined  as 0-100%, I would assume that you write an integer in the range of 0 - 100 to the particular PWM ouput you want to change.
(6,945 Views)
