FieldPoint Family
How can I reboot my FieldPoint from an embedded application?
How can I reboot my FieldPoint from an embedded application that is running on this FP.
(4,512 Views)
webmeyer,
I found this by searching through the Knowledge Bases:
http://digital.ni.com/public.nsf/websearch/DFD8CB158F30788D86256E6A00755495?OpenDocument
I think it will answer your question.
Ames
(4,512 Views)
Hello.
I'm writing you about this question you made a long time ago...
Did you solve the problem? I have the same question! So please let me know if you found a solution.
I saw the answer which was given to you, but I doubt that the reboot command would work from an embedded application, because it asks for IP address and MAC, while it is on the machine where the project is running that I want to send the reboot command. Did you try it?
Thanks for the help.
Francesca
(4,063 Views)
Francesca,
You should be able to use the RT Reboot Controller.vi to accomplish this.  The help for this function inidcates that it can be used to reboot the controller it is running on.
(4,059 Views)
THANK YOU WAYNE!
I will try it as soon as possible!
F.
(4,055 Views)
