10-13-2004 09:38 AM
10-13-2004 10:35 AM
04-21-2009 08:25 AM
Hello.
I'm writing you about this question you made a long time ago...
Did you solve the problem? I have the same question! So please let me know if you found a solution.
I saw the answer which was given to you, but I doubt that the reboot command would work from an embedded application, because it asks for IP address and MAC, while it is on the machine where the project is running that I want to send the reboot command. Did you try it?
Thanks for the help.
Francesca
04-21-2009 09:07 AM
Francesca,
You should be able to use the RT Reboot Controller.vi to accomplish this. The help for this function inidcates that it can be used to reboot the controller it is running on.
04-21-2009 09:23 AM
THANK YOU WAYNE!
I will try it as soon as possible!
F.
