FieldPoint Family
Damaged AI-110 channel
Hello
(3,194 Views)
If the channel was damaged dues to excessive currents.  An external circuit could be used to limit the +/- 30 mA limit per channel.
A zener/resistor combination circuit could be used to limit excessive currents.  While in most cases, this will protect the module, zeners with worst case leakages could add from 3 to 16 LSB of non-linear error on the 16 bit module.
Micaela N
(3,178 Views)
