02-06-2006 07:09 PM
02-07-2006
01:45 PM
- last edited on
03-01-2024
10:49 AM
by
migration-bot
Hello ssilk,
What you describe is possible. You will not have to buy LabVIEW Real-Time as long as you purchase a Fieldpoint interface that is not a controller interface. The cFP-1804 or 1808 should work well. However, to perform the type of measurement/control you want, you will have to have a host computer that interfaces to both of these banks at all times to read the input of one and output to the other. If instead, you purchased one controller interface the and LabVIEW RT module, you would be able to do the same thing without the constant interaction of the host computer.
Hope this helps,
Laura
02-07-2006 06:20 PM
02-08-2006 04:17 PM
Hello ssilk,
Unfortunately, to use Fieldpoint, you either need to have one controller that can run a control program itself (hence the need for LabVIEW RT) or a PC to run the program and communicate with the two fieldpoint setups. I am not aware of any other way to do an application like you described.
Laura
