Feedback on NI Community
rating history flipped?
Looking at the congratulation thread, I know that I have given all earlier contributors 5 stars and there just was a new message by Laura that I haven't seen (and rated) yet.
However, If I look at the thread (yes I am logged in as me), I cannot rate Laura's post, but seem to be able to rate all earlier posts twice. From my understanding of the forum mechanics, I should still be able to rate Laura's post, but not all others above it
Something is backwards....
Message Edited by altenbach on 01-24-2007 04:28 PM
(7,090 Views)
i think as for we being unable to rate Laura is because she is an admin (permission setting?? admin + blue = cannot be rated??)... she automatically get 5 stars Smiley Surprised ... as for the double rating, i think i've experienced it once too... but its only once and i forgot which post was it... and i'm unsure if Laura was in that post too...
Best Regards,
JQ
LV 8.0 user...
(7,081 Views)
Explanation from someone who studied this: Laura's posts are all automatically rated and can not be rated again (see her profile. She has no number of stars).
This is indeed because she's an admin. See here. Nick had the same thing.
The forum does not remember the history of stars after it's reset, which is why you can re-rate posts. See here.
___________________
Try to take over the world!
(7,074 Views)
You all are correct - my messages aren't rateable because I'm an administrator.  It turns out that this is an option that I can change (and I did change it).  I don't believe this was always the way the forum worked.  I certainly don't see a problem with being rated!
Thanks   Smiley Happy
Laura
Edit::  You will only be able to rate my posts starting with this one, not my previous posts.
Message Edited by Laura F. on 01-25-2007 01:03 PM
(7,057 Views)
You only addressed my second problem. 😉
The main problem reported was the fact that I apparently can rate posts that I have rated in the past. So the complementary question is "How long does the system remember that I rated a certain post and after what time does it allow me to rate it again". (... or what triggers such a memory loss)
(7,049 Views)
Well, I did give a link explaining this. What it doesn't say is when the server is rebooted, but I assume you can't know that in advance.
___________________
(7,046 Views)
Hi Altenbach,
tst is correct - the ratings are apparently reset when Lithium's server is restarted.  The information I see about this issue is that it may be fixed in an future release, but I don't know when.   I guess time will tell!
Laura
(7,032 Views)
