Feedback on NI Community
probleme mesure avec module 9205
Bonjour
une question sur un module compact daq 9205, je fais l'acquisition en tension d'un signal qui varie entre 0 et 50mV, la mesure se fait normalement avec un petit probleme.
la source de tension est stable ( par ex: 10mV) et lorsque je fais l'acquisition mon signal fluctue je dirai meme qu'elle est pertubée avec des pics de tension
est ce que mon module peut mesurer des tension aussi faible ? ou alors savez vous d'ou peut venir mon problème
merci
Message 1 of 10
(11,012 Views)
This forum is for posts about the operation of the LabVIEW forums.
You should post your question in English to the
Multifunction DAQ board
or in French to the
Discussions de produit de NI French forum
Message 2 of 10
(11,009 Views)
I try to send my message on the french board but I can't choose it on my browser
Message 3 of 10
(11,006 Views)
This seems to be the same problem as here.
Laura: This needs to be fixed ASAP.
Message 4 of 10
(11,002 Views)
Go to the French board at the link above.  It gives you the list of all the latest message threads.  Click New Message and go from there.
As S-mercurio said, it was recently noticed that there was an issue with the drop down board list.  Is that what you were trying to use to get to the French board when you had a problem?
Message 5 of 10
(10,998 Views)
RF,
The problem is the silly interface that the boards have with respect to trying to post a new message. Even if you're in the board that you want to post your question, clicking on New Message, as you know, actually performs a search first. This will present a listing of search results, along with a "Post this Question" button. That button then takes you a "New Message" page, which has a dropdown to select the board where you want to post the question. Unfortunately, it does not automatically fill in the board you came from, and the dropdown doesn't show all the boards. There's a "More" button at the end of the dropdown which display a popup, but that popup does not work properly.
A very cumbersome interface, in my humble opinion.
Message 6 of 10
(10,994 Views)
I'm not someone who posts new questions very often.  I'm usually just replying to existing threads.  And if I was starting a new thread, it is unlikely that I'd be going to one of those threads that seem to be missing from the drop down.
I agree the extra step of searching is kind of a nuisance.  Though, I see the point of it by trying to force people to search for an answer before actually posting the question.  Imagine how many more "how do I write my data to Excel" questions we'd be seeing then?
I agree the drop down needs to be fixed.  I wonder how long it has been malfunctioning?  It seems like it must have been a while.  But I really suspect very few people actually use that dropdown, otherwise we probably would have heard of the issue before now and not with just the 2 or so recent threads that seem to mention it.
The broken dropdown/dialog box shouldn't be causing anybody to post in the wrong thread.  Those threads that seem to be missing from the dropdown (an thus under the broken More? category) still have quite a few new threads being posted.
Message 7 of 10
(10,987 Views)
you know,  I swear, (frequently, at my inability to type), that, before the latest change to the "bars" I could post a new thread without a search first after about 200 posts---  now I can't.  I'm with Bill on this.   I try to post responses to threads- until the late nuggets-but starting threads has become a search first then did you?... thing for me.  Knights?, Vets?  Act Parts? has anyone else seen this.
Laura, did something change on this?
"Should be" isn't "Is" -Jay
Message 8 of 10
(10,979 Views)
Tests
Yes something changed!
Message 9 of 10
(10,976 Views)
There was an issue introduced conveniently right when I went out of the office.  I've implemented a workaround that allows new threads to be started in all boards.  Just go to the board and click New Message.  The search step is being skipped for now.
Laura
Message 10 of 10
(10,951 Views)
