Feedback on NI Community
image extensions should not be case sensitive!
So I wanted to insert the link to the picture attached here via its URL, but it gets rejected by the import tool.
If I change the extension on the URL to lower-case png, everything works fine, even though the link actually points to an upper case PNG.
I think the photo import tool should ignore the lettercase of URLs..
(3,239 Views)
This has been a problem for a long time.  I was unable to find where I brought it up.
GCentral
(3,194 Views)
Obviously, there is a list of allowed image types as identified by their extension. Apparently, this list is lowercase, so any extension needs to be converted to lc before checking.
(There is also a list of allowed file types for attachments. Is that one case insensitive?)
(3,187 Views)
Hi there! We've fixed this. Can you please do a quick test to confirm it's working now?
Jenny B
NI Community Support
(3,157 Views)
Let's see if this works...
Direct paste:
https://forums.ni.com/ni/attachments/ni/130/17851/1/Capture.PNG
Nope.  If the extension was lower case, that pasting would have inserted the image.
Using "Insert Photos":
Capture
That worked!  So I would say you have half the solution...
GCentral
(3,155 Views)
