06-22-2011 04:52 AM
is that you can help me?
hello,
I made a prog that makes the wavelet image compression but
I found some problems, it gives me nothing.
thank you so much
06-22-2011 08:48 AM
You posted a question in the forum that is for feedback on how the Discussion Forums operate.
You need to post your question in the LabVIEW board.
06-22-2011 09:19 AM
This sounds more like a matlab problem.
06-22-2011 09:33 AM
You're right. I hadn't opened the VI to see there was a Matlab node in there.
06-22-2011 09:43 AM
Unfortunately, we don't have a matlab board. (I don't know if these functions are also supported in mathscript.).
(You are also using a toolkit that is not part of plain LabVIEW. Maybe the vision board would be more appropriate.)
06-22-2011 09:57 AM
but how can i put my VI in LABVIEW board ?
06-22-2011 10:06 AM
You can click on "options...report to moderator" (upper right corner of post) and aks for the thread to be moved elsewhere.
06-22-2011 10:50 AM
sorry , i dont find it , can you transform my VI to LABVIEW board ?
06-23-2011 02:09 PM
It's here:
