Feedback on NI Community
Who's been messing with the formatting?
@Ravens Fan wrote:
@Laura F. wrote:
Ravens Fan - I see the bad formatting issue with compatibility on.  Is that the case for you or is it really with compatibility off?
Edit: Also I just double-checked and the autosave problems happen with compatibility on, so if you see the same behavior as me hopefully you can use IE8 with compatibility off for now.
Also, I was expected the autosave bug to be fixed soon so I will double-check on that.
Laura
It really is with compatibility mode off.
Compatibility mode on, problem with autosave, formatting of the message grid is fine.
Compatibility mode off,  no problem with autosave, but the formatting of the message grid had problems with some lines droppin lower than they should.  Sometimes more, sometimes less.  Sometimes they will completely drop into the messages below.
Ravens Fan - I just tried to reproduce the autosave issue in IE8 with compatibility on and off. Both times I could not get the problem to happen. I know there were some updates made last night so would it be possible to check today?
Laura
Message 61 of 97
(5,094 Views)
Also:
If you start seeing the missing style sheet issue in Firefox again, in addition to capturing the HTML in a text file, could you please try:
  • Clearing your cache / cookies
  • Send a screenshot of the reults of nslookup ni.i.lithium.com from the command prompt. You can email this to me if you don't want to post it. PM me for my email (or guess it)
My fingers are crossed that you won't see the problem again, but just in case....
Laura
Message 62 of 97
(5,093 Views)
@Laura F. wrote:
The next time you see formatting issues in Firefox, can you please grab a screenshot? I've seen the issues in IE and need to know what's going on in Firefox. The other thing that was requested is to grab the html source of the page when you see it messed up and paste it into a text file.
I had already posted a screenshot in the beginning message of this thread. The regular clearing of cache and cookies has never worked. If it happens again we'll see about grabbing the information you requested in this message as well as the other about the nslookup.
Message 63 of 97
(5,090 Views)
It got much worse!! IE6 & Win XP Pro. Firefox is good :) 3 cheers for Firefox I cannot add more than 1 attachment
Message 64 of 97
(5,087 Views)
here's the 2nd attachment. I'll edit using Firefox..
EDIT:>> HEY!!  It didn't even upload the attachments!!!!
Message 65 of 97
(5,085 Views)
Ray - your screenshot is from IE6, correct?
Message 66 of 97
(5,071 Views)
Sorry - I thought you were seeing something different.
Message 67 of 97
(5,069 Views)
Yes.
I just tried IE8 and it appears fine.  We just have to stay away from IE6  😉
Message 68 of 97
(5,063 Views)
I'll try and attach the Firefox image and page source. The page source is zipped
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 69 of 97
(5,051 Views)
Thank you!!
Message 70 of 97
(5,044 Views)
