Feedback on NI Community
Unable to drag code snippet into Block Diagram
Windows - 7
Internet Explorer 8.0
LabVIEW 2010
Tried to drag a snippet that I posted on the forum into the block diagram and it would not do it.
With Firefox, I get the usual url text (I know it is not supported).
Anyone else having problems with the above combination?
Message 1 of 8
(10,650 Views)
Accepted by topic author Ray.R
I don't think you can drag directy from the browser. do a "save picture as..." and drag it from the file manager to the diagram.
Message 2 of 8
(10,649 Views)
Thanks Christian.
I tried it and of course it works (even with Firefox, as expected)...
When did this change?
I
Message 3 of 8
(10,646 Views)
For me, it never worked by dragging directly from a browser.
Message 4 of 8
(10,639 Views)
Well, that's odd because it has worked for me, as long as I used IE. Dragging a snippet from Firefox doesn't work, but this is a known issue.
Message 5 of 8
(10,627 Views)
Hi Saverio,
I know..  I always dragged it from IE.  Except for this WIn 7 machine.  I will check to see if another machine has IE8 and try it.
I do like Christian's trick, since it's a nice workaround for Firefox.
Message 6 of 8
(10,613 Views)
A couple of other options:
I modified the GetSnippet RCF plugin to retrieve the snippet from a URL on the diagram -- just drag the URL across from any browser, and then click to get the snippet.  The file is here.
Also, another user has created a QuickDrop plugin, if that's the way you swing.
Message 7 of 8
(10,594 Views)
Greg,
I was unaware of those plugins.  Thanks for sharing.
Message 8 of 8
(10,583 Views)
