Feedback on NI Community
Text overlap in IE8 (double vision)
Feels like double vision.
Running Win7
See below
(6,620 Views)
Ray,
This looks like something I saw a few months ago and first reported back in this thread.  I haven't seen it in a while.
Check to see if compatibility mode is turned on for you in IE8.
(6,612 Views)
Hi Ravens,
Compatibility mode was not turned ON.  I just turned it ON now.
I usually browse using Firefox, so IE not typically not my first choice of browser.
I will check out your thread.
RayR
(6,597 Views)
I used to see something similar but not quite so bad fairly often.  However, I've checked multiple other computers and so has Lithium and I could never reproduce any where but on my computer so I figured it was something very specific to me. I will report that you are seeing the issue too. I sometimes found it would go away as I resized the width of my browser window.  I can't get the problem to happen as easily now.
(6,590 Views)
Thanks Laura,
It happens with or without Compatibility Mode turned ON.  With it turned ON, it appears to be less apparent.  However, I did notice something else.  All the first post in a page is offset at the top.   This happens consistently.   See below:
(6,579 Views)
