Feedback on NI Community
Text/Attachment not showing in IE
The post here looks completely blank in IE (picture), while in firefox I see the text and attachment.
http://forums.ni.com/ni/board/message?board.id=170&message.id=205124#M205124
The immediately following post does not show the attachment in IE.
Does anyone else see the same behavior?
Message Edited by altenbach on 09-13-2006 12:37 PM
(6,225 Views)
I don't have Firefox, but I'm not seeing anything in IE either (nor after opening the source HTML, naturally).
Maybe a problem in the way IE works with Javascript?
Maybe it just doesn't like it when people mispell (or is it mispell? Smiley Surprised ) your name?
___________________
Try to take over the world!
(6,210 Views)
If you try to reply in IE, then quote the post, some fancy html shows up:
<TABLE id=HB_Mail_Container height="100&#37;" cellSpacing=0 cellPadding=0 width="100&#37;" border=0 UNSELECTABLE="on">
<TBODY>
<TR height="100&#37;" UNSELECTABLE="on" width="100&#37;">
<TD id=HB_Focus_Element vAlign=top width="100&#37;" background="" height=250 UNSELECTABLE="off"></TD></TR>
<TR UNSELECTABLE="on" hb_tag="1">
<TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
<DIV id=hotbar_promo></DIV></TD></TR></TBODY></TABLE>
<BLOCKQUOTE id=c4b84c75>
<DIV></DIV>
<TBODY>
<DIV>Yes, it worked before. We moved the lab, reinstalled Window XP and labVIEW. After that, it worked a few times. We tried to connect to different serial port. it didnot help.</DIV>
<DIV>&nbsp;</DIV>
<DIV>Sorry, I donot know about the provided code you mentioned.</DIV>
<DIV>&nbsp;</DIV>
<DIV>I can access the block diagram.</DIV>
<DIV>&nbsp;</DIV>
<DIV>I attached the labview program we used.</DIV></TD></TR>
<DIV id=hotbar_promo></DIV></TD></TR></TBODY></TABLE></BLOCKQUOTE>
<P>Message Edited by Cuiling on <SPAN class=date_text>09-12-2006</SPAN> <SPAN class=time_text>04:27 PM</SPAN>
<HR>
I wonder if that "id=hotbar_promo" string would indicate some malware infection that tries to add stuff to posts and thus interferes in some way.
(6,206 Views)
I looked at the source HTML again, and it looks like the text and link to the attachment do appear in there.
Also, the hotbar tag appears with each of that user's postings.
___________________
(6,200 Views)
Yeah that was weird.  It was something going on with all the HTML in his posts.  Not sure where it is coming from.  I removed all the HTML and now it looks normal in Firefox and IE.  Let me know if any of you see this again.
Thanks!
(6,162 Views)
