Feedback on NI Community
Problem switching from a non Idea Exchange board to an Idea Exchange board when typing a new post
Tested on Chrome/XP and IE8/XP
when I start a post in a non Idea Exchange forum and later on want to convert it into an Idea Exchange one, I can switch to the correct forum using the "Select Board" pull-down list. However, when posting, my post is refused because I haven't chosen a "Label". Well, that's because I can't!
In other words, switching to an Idea Exchange board does not add the "Label" options on the composition webpage, hence it is impossible to post that idea unless you copy it (or rely on the autosave function), start a new post directly into a Idea Exchange forum and paste your old post in it (or alternatively, load the saved draft once you have created the new post).
Disclaimer: this may have already reported, but as I said elsewhere, the Search function doesn't work either...
Message 1 of 1
(5,945 Views)
