Feedback on NI Community
Problem sending message with Firefox
Not at all....
Although with many years experience configuring machines, flattening them often fixes many problems. Some due to patch installation sequence and others due to fatware no longer required.
I had hoped firstly by demonstrating that I was using a similar configuration that it does work.
Secondly that often some basic maintenance can fix many issues.
Thirdly by engaging in discussion it might encourage others.
Fourthly perhaps two heads are better than one.
There do appear to be some issues related directly with Firefox as I noted here with the javascript inclusion.
Message 11 of 18
(2,925 Views)
I have a brand new, out of the box PC, installed Firefox, same problem...
LabVIEW, C'est LabVIEW
Message 12 of 18
(2,869 Views)
Ouch........
That hurts.....
I will try and dig out some French localised software and see what I can replicate.
Message 13 of 18
(2,859 Views)
Don't waste time on localization. I tried on a fifth PC with both English Windows XP and Firefox. Same problem...
Message 14 of 18
(2,854 Views)
Not sure what to suggest after this point.
I will keep an eye out and if I observe anything, good or bad I will add a note here...
Message 15 of 18
(2,854 Views)
I have also this incomplete page for New Message (attached).
By the way,
"...maintenir une langue propre."
Keep a clean tongue...Always a good idea... 😛 Dirty words are bad.
Elsewhere it is better translated as " maintenir la même langue du message source."
Message 16 of 18
(2,843 Views)
You'll find that funny, in one of my macros (an hyperlink to OpenG) there was a missing double quote that messed with the rest of the page code... The New Message page is also fixed.
That would have never happened with LabVIEW...
Too bad I found that after reformatting 5 computers... 😉 kidding
I HEAR YOU LAUGHING!
Message 17 of 18
(2,836 Views)
I am really glad that it works, it was the least I could do to offer moral support.
Now check out the post that I sent with the Javascript code attached ....... using IE 6
There should be more posts below it and then the standard page footer.
Perhaps I need to format the hard disc... ohh no need, it's IE 6, it's always bust... 🙂
Then again it could be the forum engine.
'Vive la difference'
Message 18 of 18
(2,823 Views)
