Feedback on NI Community
GPIB-232CT-A Serial commands problems
Hi
I am using the GPIB-232CT-A to send commands to a network analyser using the serial coms commands and I am having the following problems:
1) Network analyser only responds to the command only if I reset the analyser.
2) I cannot send more than 2 commands. The analyser only responds to the first command.
Do you know which commands I must use to send more than one command without having to reset the analyser everytime I need to send the command.
The command that I use is 'wrt ' .
Thanks in advance.
(5,156 Views)
it would be better if you re-post this here http://forums.ni.com/ni/board?board.id=140
regards
Ray Farmer
Regards
Ray Farmer
(5,148 Views)
