Feedback on NI Community
Close parenthesis displaying as smiley faces makes code difficult to read and copy
My posting at http://forums.ni.com/ni/board/message?board.id=330&message.id=22047&jump=true has close parenthesis and they appear as smiley faces on my system. Is this a known issue or something with just my system?
example1("hello", "world")
example2("hello", "world" )
It appears to be when a " follows a ) character in the html.
Message Edited by Scott Richardson on 11-14-2008 11:19 AM
Scott Richardson
https://testeract.com
Message 1 of 16
(8,852 Views)
Message 2 of 16
(8,845 Views)
Feature request (however I don't see why anyone should post alphanumer code :smileywink:
Maybe a code box (just like IPBoards).
Ton
My LabVIEW Ideas
Message 3 of 16
(8,833 Views)
Scott,
You can make a change in your forum preferences so that emoticons don't display unless someone has purposefully inserted an emoticon using the insertion box.  Set Emoticon Type to None in your preferences.
Laura
Message 4 of 16
(8,810 Views)
Laura F. wrote:
Scott,
 ... unless someone has purposefully inserted an emoticon using the insertion box.  Set Emoticon Type to None in your preferences.
Laura
Except that the new insertion box is a real pain to use. Smiley Wink
Message 5 of 16
(8,792 Views)
I gave this kudos and then realized that that wasn't enough to show I much I agree with this, so : I AGREE WITH THIS.
Laura, the new editor still sucks (and that includes all the popup windows it has). The older one was easier to use and worked faster, and personally, I would prefer that you reverted back to it if possible.
___________________
Try to take over the world!
Message 6 of 16
(8,790 Views)
Laura -
As a user this solution is not obvious and might be frustrating to customers when trying to read postings. Thanks for letting me know. My initial thought is that the option should be on the writers side, not on the readers. Maybe make the default for new users None. Thanks...
Scott Richardson
Message 7 of 16
(8,788 Views)
I'll second that!  Or maybe I'm technically third.Smiley Wink   (Note 7 seconds to wait for that to emoticon popup to load, blink at me a few times, and finally get to a point where you can click to enter it).  I want to say it was only 1-2 seconds under the previous editor.  I also find with this one, if you click on something before it's completely loaded, it will freeze at a point where you can't insert one.  Then you have to X out the window and start all over again.
Message 8 of 16
(8,784 Views)
This was brought up when the upgrade was first rolled out, and taken up again by Ravens Fan with a good point about the other "faces".
Message 9 of 16
(8,777 Views)
I would prefer to see all the classical "typed" smileys, except for the "double-quote + right-parentesis". This one is just silly and redundant.
Message 10 of 16
(8,775 Views)
