Feedback on NI Community
CLF on VI Hierarchy
Anyone notice the new feature of LV2009?  Now you can see CLF on VI Hierarchy window.
Nice feature.  Now everyone can sneak peek what's behand NI's password protected VIs.
Is this a bug or what?  It should never worked for password protected VIs!  It enough works for diagram removed VIs!!!
George
George Zou
(7,263 Views)
You can post here
This is feedback regarding the forum
(7,244 Views)
(7,241 Views)
 I suppose clf
(7,239 Views)
Call library function :smileytongue:
(7,238 Views)
Are you serious??  😮
My trial version of LV2009 just ended, so I cannot check it out.
That's horrible if true..  😮
(7,224 Views)
I don't quite understand the issue. OK, so you can see the Call Library Function Node. It tells you the name of the DLL and the function being called. That's it. No parameter information, or what's actually wired to those parameters. How does that provide information on what the block diagram is actually doing?
(7,203 Views)
